reseting car alarm
Old May 28, 2006 | 03:55 PM
markeabaker's Avatar
markeabaker
Default reseting car alarm
ok my 2002 used durango slt has alarm on it my durango was pushed with out the car alarm being un activevated and now it want start i have tried disconeting the battery and fuses re contecting them do no avale what di i need to do to reset the the ingetion sytems as everythings else works
Old May 28, 2006 | 04:01 PM
yakkier's Avatar
yakkier
Default RE: reseting car alarm
i need a lil more detail as to what your problem is, i understand the alarm wil not activate correct ? if that being the case check the fuses to see if it's blown, an check your battery in your remote, sometimes its the simple things we over look. If both are fine i would take it to the dodge dealership an have them reprogram the remote an do a systems check on the alarm, usually if it isnt activating properly they can usually use one of their "universal" remotes to try every signal they have an see if that will activate it, if they find a different signal than what your remote is programd for then they'll just reprogram your remote. Hope this helps
