abs brake lights still on!!!
Old Jun 8, 2006 | 10:37 AM
98durangosc's Avatar
98durangosc
Default abs brake lights still on!!!
HI IM NEW HERE,HOPE I GET HELP,MY ABS AND BRAKE LIGHTS COME ON EVERY ONCE IN A WHILE. IF I TURN OFF/ON THE LIGHTS GO OFF.SOME DAYS THEY DONT EVEN COME ON. I THOUGHT IT WAS THE REAR WHEEL SENSOR SO I REPLACED IT AND DISCONNECTED MY BATTERY FOR A COUPLE MINUTES BUT A COUPLE DAYS LATER THEY CAME ON WHILE DRIVING.SPEEDOMETER WORKS,BRAKES WORK NO CHECK ENGINE, WHAT COULD IT BE PLEASE HELP I WANT 2 AVOID TAKING IT 2 THE DEALER$ ANY PICS WOULD HELP A LOT
Old Jun 9, 2006 | 03:27 AM
yakkier's Avatar
yakkier
Default RE: abs brake lights still on!!!
ORIGINAL: 98durangosc
Since u checked the speedsensor in the rear end, your abs sensor maybe going bad, or a wire is loose on it, go around check all the sensors an go buy some electrode cleaner, it cleans grime an buildup off of the inserts. Try that an if it doesnt work your speedsensor might be getting ready to go bad, even though u did check it, ya never know.. also sometimes it's best to just bite the bullet an take it to the dealer, trust me i'v had to do it many of time's an i want to do anything an every thing my self..
Old Jun 11, 2006 | 02:05 AM
spectre184's Avatar
spectre184
It could also be the control module up on you drivers fender well. The cylinders that work your ABS are hooked to them by couple of wires. Another website forum (Dakota but pretty much same info for both) said they were being replaced at dealer for $200'ish for module alone. But if you buy it the dealer has to reprogram it (dunno how true that is).
That thread, most people who had the symptons the sensor didnt fix problem. You'll know when that sensor goes out as your speedo doesn't work until 30mph. My brothers D just did this and we replaced sensor 2 days ago. OPS check good! My D those lights comes on every now and then. Doesnt really bother me.
If you really want to read thru 8 pages of threads: http://www.dodgedakotas.com/boards/dea/168-1.html
Old Jun 11, 2006 | 08:28 PM
hydrashocker's Avatar
hydrashocker
Have your brake fluid changed out. You might have a guming or air bubble problem.
Old Jun 11, 2006 | 09:39 PM
yakkier's Avatar
yakkier
or just bleed the system lol
Old Jun 11, 2006 | 10:12 PM
hydrashocker
The manufacturer say's you should have the fluid changed out every 60K. The seals can rot or bad gumming can build up in the lines from hot calipers.
Old Jun 11, 2006 | 10:17 PM
yakkier's Avatar
yakkier
seriously?
