running hot
Old Jun 14, 2006 | 10:00 PM
rlueras's Avatar
rlueras
Default running hot
I have a 1998 durango 5.2 4x4. I replaced the radiator and thermostat and fan clutch about 8 months ago due to a plugged radiator. now it is when i drive it for about 30 minutes in town or on the highway it starts running around 230-240 F. when you deccelerate it cools a little. i have tried driving with no ac and with ac and no difference. I also noticed when i pull anything it heats alot faster. i just had a oil change and went with valvoline maxx life sythetic. (no Change). The water pump isn't leaking out the weep hole but i have heard that some won't when they go out. is there any suggestions before i change the water pump. Thanks
Old Jun 21, 2006 | 12:04 AM
GhostRider3387's Avatar
GhostRider3387
Default RE: running hot
Did you replace the hoses when you replaced everything eles ? Sometimes a weak hose will suck shut and prevent the coolant from flowing.
Old Jul 2, 2006 | 10:03 PM
hydrashocker's Avatar
hydrashocker
Also check the trans filter. And check for back pressure on the Cat.
Old Jul 3, 2006 | 12:44 PM
Chris_Gorham's Avatar
Chris_Gorham
check my response to post by Rocky - you may need to pressure wash your A/C condensor as well...Chris
Old Jul 5, 2006 | 02:56 AM
1 bad durango's Avatar
1 bad durango
have the dealer check your timing if you are moving and the car heats up ,but when u stop it cools down ,it is a tale tale sign of improper timing
