Shorting out? Wiper related?
Old Jun 27, 2006 | 09:18 PM
DuragoFett's Avatar
DuragoFett
Default Shorting out? Wiper related?
Ok, You may remember I had the stalling Engine, drained battery . Well the battery was recharged & been running so far BUT, the Winshield wipers are Erratic. From position 1-4 delay, the wiper will wipe from 1-6 time in a row before it will delay. And the other day while turning off the Durango, even had the key out, and heard the All-too-familiar sound of Something, clicking on & off draining on the battery. I was assuming a short, but wouldn't wipers While Vehichle off, not be able to draw on the Battery? Are the wipers related to, or a separate issue? Timing relay in wipers? I've got a '99 Durango. Anyone have any shorting Problems Period?
Old Jun 27, 2006 | 09:46 PM
yakkier's Avatar
yakkier
Default RE: Shorting out? Wiper related?
if it's the rear, there is a box fuse connected to motor, you could try replacing that, if it's the fronts then try an replace your mastrecontrol switch, they'er about 40 bucks but worth it for a new one
