vaacum problems
Old Jul 19, 2006 | 08:14 PM
pizmp420's Avatar
pizmp420
Default vaacum problems
i need help i have a 1998 dodge durango and every time im in drive or reverse it makes a whineing noise and we took the 4x4 out of 2h into N and i called my uncle to see if he knew anything since he worked for dodge and he said it could be the vaacum ... but where is it located at.....anybody else have da same problem
[IMG]local://upfiles/40082/A744480D21F345AB946843FD4E01BF0D.jpg[/IMG]
Old Jul 25, 2006 | 02:16 AM
1 bad durango's Avatar
1 bad durango
Default RE: vaacum problems
your best bet if you really think its a vaccum leak take it to the dealer and have them hook it up to a fog machine then look for the smoke hope it helps
Old Jul 25, 2006 | 03:13 AM
IndyDurango's Avatar
IndyDurango
ORIGINAL: pizmp420
Whining noise in reverse.... sounds like you have a rear differential going bad. They will whine alot before they go out completely so you have time to get it fixed.
A good friend once said, "Remember: Diffs are like women. They'll whine and howl for a long time before they leave you. "
(Thanks Bill!)
IndyDurango
