1998 air flow problem
Old Jul 20, 2006 | 11:02 AM
joev's Avatar
joev
Default 1998 air flow problem
I own a 98 durango and I noticed that when I run the A/C the output from the upper vent passenger side is not as strong as the output from the drivers side. I assume that this holds true no matter what I have my control set to (heat/A/C, etc.). Does anyone have an idea as to what may be causing this problem (air hose problem, etc.). All the other vents have high output. Thank you.
