2001 durango misfire
Old Aug 5, 2006 | 11:31 AM
sparks454's Avatar
sparks454
Default RE: 2001 durango misfire
Finally nailed it down. Installed new fuel pump and she ran better but still had a miss...Pulled the injectors and soaked them in some cleaner for a short while. Installed new o-rings and she runs better than new now...Thanks for all your input.
Old Aug 5, 2006 | 07:44 PM
Mean Green's Avatar
Mean Green
Good stuff sparks! Glad your D is back to being well mannered.
Old Aug 7, 2006 | 04:18 PM
AnotherPepsi's Avatar
AnotherPepsi
Hey Sparks. Did the fuel pump have the filters?
Old Aug 7, 2006 | 04:25 PM
sparks454's Avatar
sparks454
Part was $215 from Carquest w/lifetime warranty. It is the ENTIRE unit. The pump,filter(which is inside the case), the level sensor(float) and the regulator which is mounted on top of the assembly. Took about 1 hour to remove the old unit and install the new unit.
