biggest tires on a stock durango
Old Jun 28, 2004 | 06:25 PM
bursty's Avatar
bursty
Default biggest tires on a stock durango
What is the biggest tire that i can fit on a stock 98 Durango? I want to try to put 33s on but someone told me 33s would not fit. Anyone know?
Old Jun 28, 2004 | 06:39 PM
Saint's Avatar
Saint
Default RE: biggest tires on a stock durango
32 is largest that I would go, and even then you may still have to crank on the torsion bars to get them to fit.
Old Jun 30, 2004 | 05:09 AM
Bamboo's Avatar
Bamboo
I concur, 32 X 11.5 is the largest size you can go on a stock height Durango. You may have slight rubbing at the frame on full lock but not enough to bother with. I have a few Durango buddies that run them.
Old Jul 14, 2004 | 07:37 PM
robust57's Avatar
robust57
33's won't work. I've been running 32x11.5 on the stock 15 rim for my 98. I've used a set of Pathfinder ATR's (great tire) which had a little rub, then I got the BFGoodies M/T's (won't buy again) and have a little more rub due to the side walls having ***** on them. the rubbing isn't anything to worry about though.
