A/C blower motor issues
Old Aug 7, 2006 | 11:45 PM
bigbill7501's Avatar
bigbill7501
Default A/C blower motor issues
Well i am normally on here for my dodge ram but now i have a question on my wifes 2003 durango the a/c blows cold but it only works on high all of the fuses are good any input would be nice THANX..
Old Aug 8, 2006 | 01:08 PM
Kensai's Avatar
Kensai
Default RE: A/C blower motor issues
ORIGINAL: bigbill7501
You will need to replace your resistor pack that controls the fan speeds on your fan motor. Dealer part only. Cost is anywhere from $14-$20. Resistor pack is located underneath passenger side. When you look, look towards the console. You will see a wire harness attached to the air vent duct. You will need a 7mm or 8mm socket with ujoint attachment as one of the two screws is hard to get to using a straight shaft. Basically a 5-10 minute repair job. This problem is very very common on all 2001-2003 2nd generation redesigned interior Durangos.
This continuing re-occuring issue needs to be permanently stickied on the top of the 1st gen forum.
