Brake, but no tail lights
Old Sep 1, 2006 | 04:28 PM
DSzabo's Avatar
DSzabo
Default Brake, but no tail lights
I have a '99 Durango 5.8l 2x4. My tailights and speedometer light went out simultaneously, but the brake and turn signals work fine. I checked the wiring, the fuses in the fuse box under the hood, and the bulbs in the tailight assembly.
Any ideas?
Old Sep 1, 2006 | 07:00 PM
Mean Green's Avatar
Mean Green
Default RE: Brake, but no tail lights
Maybe it's a ground wire? Check all of your grounds to make sure they're not loose. Get a haynes or chiltons manual and check the wiring diagram for the locations. 5.8L hmmm never heard of that one. [sm=icon_stickpoke.gif] j/k
Old Sep 2, 2006 | 11:39 PM
HotRod53's Avatar
HotRod53
Does the '99 have another fuse panel on the side of the dash when you open the drivers door? Almost has to be a fuse....
Old Sep 2, 2006 | 11:45 PM
Mean Green's Avatar
Mean Green
Those are tiny fuses in there I doubt it is in there. Just have to check the owners manual basically...
Old Sep 3, 2006 | 02:46 PM
hydrashocker's Avatar
hydrashocker
I just looked in my truck on the drivers side dash fuse panel and those fuses are in there.
Also check under the hood inside the main panel.
