intake manifold gasket
Old Jul 11, 2004 | 05:36 PM
nobuosan's Avatar
nobuosan
Default intake manifold gasket
Is there any way to know if the intake manifold gasket is bad without removing the intake manifold?
Old Jul 12, 2004 | 03:27 AM
Bamboo's Avatar
Bamboo
Default RE: intake manifold gasket
ORIGINAL: nobuosan
Disconnect the intake hose into the air hat on top of the throttle body. Remove the air hat, hold open the throttle body blades and look down inside with a flash light to the belly pan gasket. A very light sheen of oil is normal, anything else and you've got a problem. Your oil consumption increases pretty dramatically, could be as much as one quart or more every 500 miles. You could also start pinging/detonating very easily under load. There is also a vacuum test that the dealer does but I'm unsure of the procedure. Somebody else chime in?
Hope this helps.
