Heater Blower not working
Old Oct 18, 2006 | 02:36 PM
cutter8470's Avatar
cutter8470
Default Heater Blower not working
How can you tell if its the resistor pack or the motor itself is bad?
Old Oct 19, 2006 | 12:11 AM
Kensai's Avatar
Kensai
Default RE: Heater Blower not working
No easy way. But hell, the resistor pack is only like $15 or less so I would go that route first. If replacing the resistor pack does not work, then it may be the motor or the fan speed switch but from what I have seen, resistor pack is mostly always the culprit.
Old Oct 24, 2006 | 05:17 PM
cutter8470's Avatar
cutter8470
I'll try the resistor pack first then. Thanks for the response.
Old Oct 25, 2006 | 01:36 AM
IndyDurango's Avatar
IndyDurango
I believe that if it is the resistor, then the fan will work ONLY in the high position. All other speeds will not work.
HTH,
IndyD
