Engine code P1698
Old Oct 24, 2006 | 10:35 PM
dlose9's Avatar
dlose9
Default Engine code P1698
Hello all, I had recently installed a car starter in my 01 durango and now my check engine light came on. So I hooked up my code scanner and it says P1698. NO CCD message fom TCM. Any one ever had this happen? If so how do I fix it. I checked all my wiring and everything looks ok. not sure what to do.
Old Oct 26, 2006 | 01:04 PM
Digitoxin's Avatar
Digitoxin
Default RE: Engine code P1698
Are you sure a wire harness didnt get pinched, or unplugged around the starter, like a knock senser, or crank senser?
Old Dec 10, 2007 | 04:22 PM
jack02's Avatar
jack02
If you do a search for 1698 you will find another link on this problem and how to fix it. I have had the same problem with a remote starter installed in my D
