cooling fan howls at all speeds
Old Oct 30, 2006 | 01:57 AM
gearrat's Avatar
gearrat
Default cooling fan howls at all speeds
ok i have checked the fan clutch and its good but the fan howls at all speeds and even when the temp is up. any suggestions. i did a search but the one topic that came up did not help any
Old Oct 30, 2006 | 12:51 PM
hydrashocker's Avatar
hydrashocker
Default RE: cooling fan howls at all speeds
Sounds like it is going out. Not alowing slippage like it should. Does it ever not howl? If not then replace the fan clutch.
Old Oct 30, 2006 | 01:07 PM
Digitoxin's Avatar
Digitoxin
Something I noticed also, is that a aftermarket fan clutch is much noisier then the factory, not freeing up nearly as soon. I recommend getting a factory replacement clutch.
Old Oct 30, 2006 | 03:10 PM
steve05ram360's Avatar
steve05ram360
99% of the time when I hear this it turns out the clutch is locked or near locked and is causing the problem. I'll bet your mileage dropped too didnt it?
