Hot wire for the park lamps on a 99 D
Old Jul 23, 2004 | 09:31 PM
daquinkin's Avatar
daquinkin
Default Hot wire for the park lamps on a 99 D
Does anyone know, or know of a website to get the color of the Hot Wire in the back of the switch for the Park Lamps for a 99 Durango
Thanks for any help
Old Jul 23, 2004 | 10:18 PM
rockadaous's Avatar
rockadaous
Default RE: Hot wire for the park lamps on a 99 D
[&:] good luck on that one. I had to change out my switch when mine was acting up.
Old Jul 24, 2004 | 02:15 PM
JCswm's Avatar
JCswm
HEADLAMP SWITCH C1 - BLACK 14 WAY CAV CIRCUIT FUNCTION
1 L7 18BK/YL HEADLAMP SWITCH OUTPUT
2 F33 18PK/RD FUSED B(+)
3 G16 20BK/LB LEFT FRONT DOOR AJAR SWITCH SENSE
4 G26 20LB KEY-IN IGNITION SWITCH SENSE
5 Z3 18BK/OR GROUND
6 L2 18LG HEADLAMP DIMMER SWITCH OUTPUT
7 L38 20LB/BK REAR FOG LAMP FEED
8 L107 20WT PARK LAMP RELAY OUTPUT
9 Z1 18BK GROUND
10 M112 20BR/LG ILLUMINATED ENTRY RELAY CONTROL
11 - -
12 M2 20YL COURTESY LAMPS DRIVER
13 M102 20PK/DB COURTESY LAMPS SWITCH OUTPUT
14 E1 20TN PANEL LAMPS DIMMER SWITCH SIGNAL
It's the White wire in pin 8 that goes to the relay
Let me know if that helps
John
