wont stay running
Old Dec 15, 2003 | 01:54 AM
jax_durango's Avatar
jax_durango
Default wont stay running
We just changed the water pump on my 98 durango...........we started several times to check for leaks..........started a little rough but started. Now it wont stay running though. Starts and stalls..........no sputtering, rough idle,,,,,,,,,,just stalls. I can make it run by holding down the gas but thats it as soon as let off........stalls. any ideas?
Old Dec 18, 2003 | 06:46 PM
beechnut's Avatar
beechnut
I had the same problem without the waterpump. Everytime I started it it would stall, if I held my foot on the pedal it would run.</P>
Turns out I needed a new battery, if the battery gets to low the durango forgets the throtle postion and that why it wouldn't stay running. Hope this helps.</P>
Old Jul 25, 2007 | 10:01 AM
brsbrowsing's Avatar
brsbrowsing
Default RE: wont stay running
had the same problem that the only way to keep it running was to hold the gas down. what i found was thatthe PCV valve needs to be replaced. couple of bucks. you can check by just disconnecting it and pulling it out and the engine will run fine. change it at each oil change. forget the battery for now.
Old Oct 1, 2007 | 10:07 PM
dragrcr1962's Avatar
dragrcr1962
I agree that the PCV valve could be the problem..... Had to clean mine one night when it kept dying. No doubt it WAS the problem.....
Old Oct 3, 2007 | 06:27 PM
burban2002's Avatar
burban2002
Does that happen when the engine is warm or cold? If its cold it might be the IAC. If it goes bad it wont idle when cold
