Fluid change
Old Nov 30, 2006 | 11:14 PM
kmcdonough's Avatar
kmcdonough
Default Fluid change
I have a 2003 durango 4WD with 4.7L and auto tranny. I want to change the fluids in the front/rear diff, transfer case and tranny. Does anyone know the fluid specs (type and amount) for this vehicle. I am looking for a shop manual but can't find one. Thanks in advance.
Kevin McD.
Old Dec 1, 2006 | 03:54 PM
Mean Green's Avatar
Mean Green
Default RE: Fluid change
First off you should check your glove box to see if you have an open diff or limited slip. If you have limited slip then you need friction modifier from the stealership. Two tubes, one front and one rear. I put 75-90 mobil 1 synth gear oil in mine which is cheaper than the stealers gear oil which isn't even synth. As far as amount 5 quarts should do it. I used all but 1/2 a quart on mine on my change a few months ago. Tranny needs atf 4 and holds 12 quarts but I don't know how much you actually get out since my tranny went before I did my change and the shop took care of all that. Transfer case anyone?
Old Dec 1, 2006 | 11:59 PM
kmcdonough's Avatar
kmcdonough
thanks for the info. Can you overfillthe diffs? With my 03 Ram there was much contoversy with overfilling the diffs because of the foaming that may occur with the synthetic fluid.
Kevin McD.
Old Dec 2, 2006 | 04:53 AM
Mean Green's Avatar
Mean Green
You fill them up to around 1/4 of an inch below the filler hole but I don't really see the harm if it goes all the way up to the hole.
