engine sludge
Old Dec 6, 2006 | 07:44 PM
Mean Green's Avatar
Mean Green
Default RE: engine sludge
TSB=tech service bulletin I believe.
Old Dec 6, 2006 | 09:37 PM
steve05ram360's Avatar
steve05ram360
using synthetic will help alot... if you feel it's sludged up already you might try MMO, it should clean the insides pretty well.
Old Dec 6, 2006 | 11:31 PM
deerang's Avatar
deerang
what is MMO?
Old Dec 6, 2006 | 11:42 PM
steve05ram360
marvel mystery oil... it's the bomb. do a search for it over in the 2nd gen ram forum and you'll find lots of info on it.
Old Dec 7, 2006 | 12:15 AM
deerang's Avatar
deerang
Thank you
Old Dec 7, 2006 | 03:08 AM
IndyDurango's Avatar
IndyDurango
ORIGINAL: Mean Green
Correct!
IndyD
Old Dec 9, 2006 | 01:11 AM
97 3.5 Intrepid's Avatar
97 3.5 Intrepid
Does it also effect the 3.7L V6 which is based off of the 4.7L?
Old Dec 9, 2006 | 04:30 AM
Mean Green's Avatar
Mean Green
I haven't heard anything on that but you may want to ask around in the Dak sections they would hear about that. They only made a few D's with the V6's (not sure if that is the 1st, 2nd, or both gen D's though)
Old Dec 9, 2006 | 05:18 AM
97 3.5 Intrepid
They first offered the 3.7L in 2004, right at the end of the second gen and starting the 3rd gen. Info will be limited, but they complain alot about the engines being noisy when the first start, similar to the sound of a diesel engine.
Is this oil sludge problem as wide spread and bad as the one that effected the 2.7L V6 in the cars?
Old Dec 10, 2006 | 03:25 AM
Mean Green's Avatar
Mean Green
I have heard it isn't too bad from Indy and It's not a huge problem from what I have seen on the forums but it is present.
