Engine oil grade
Old Dec 8, 2006 | 01:03 PM
dontilgon's Avatar
dontilgon
Default Engine oil grade
Iam reading about this oil sludge in our motors and is wondering what is the BEST oil GRade . I live in NY so no extreme weather. I been using 10-30 but oil change place says it recommends 5 30 ..what do u think....2003 4.7
thanks
Old Dec 8, 2006 | 07:47 PM
JasonGS's Avatar
JasonGS
Default RE: Engine oil grade
10-30 is just fine, as long as temps don't fall below 0F.
Old Dec 10, 2006 | 01:55 PM
hydrashocker's Avatar
hydrashocker
ORIGINAL: dontilgon
thanks
Just use Fully Synthetic 10-30 for best protection. Fully Synthetics will run like water even in temps of -56 degrees F. They also give outstanding protection in very hot conditions. It is best to stay with the 10-30 because it has all the stabilizing additives you need for your motor that the factory built it for. Also sludge problems are really only associated with the 4.7L. But it can happen in any vehicle.
Blends of Regular and Synthetic oils are crap so stay away from them. You either do one or the other.
Old Dec 14, 2006 | 02:46 PM
SilverGhost's Avatar
SilverGhost
I live up near Albany where we often see sub-zero temps and I've been using 10W30 in my 2000/5.9L D with no problems since it was new. But, there's apparently a lot of new thinking out there that recommends 5W30 year-round. Don't think you can go wrong with either grade.
Aside - 5W30 is the recommended grade for my HEMI powered RAM.
