Relay Questions
Greetings everyone.
I just acquired a 2000 Durango SLT, 5.9L and have some questions about the relays. When I got it, the fog lights didn't work so I started with the fuses. It was there I noticed that the fog light relay in the fuse/relay panel under the hood was missing. Since I'm not towing anything I yanked the trailer relay and used it for the fog lights. My fog lights now work, but I noticed I might be missing two other relays.
It appears as though I might be missing a "Rad Fan Relay" and a "O2 #2" relay. Does anyone know if I even need these relays?
While I'm asking questions, what about the tailgate lift supports? Mine aren't cutting the mustard anymore, anyone know of a good deal on a good set of these?
Thanks for any help in advance,
Brendan
Brendan
I would say yes to the two relays you mentioned and I wouldn't have the slightest idea on new lift gate supports other than the stealership but I'm sure you could find some online with a little searchingor you can always go to a junkyard...
