How wide can I go?
Old Dec 24, 2006 | 06:58 PM
reilly360's Avatar
reilly360
Default How wide can I go?
How wide can a clear on my 00 D. right now I have the stock 235/75/15 but I wanted to put 265/75/15 on so I have a little more rubber on the road. Will I have and clearance issues of any kind or what?
Old Dec 24, 2006 | 09:32 PM
RebelX's Avatar
RebelX
Default RE: How wide can I go?
well a 265/75/R15 is basically the same thing as a 31x10.50R15 which i am running right now with no clearance issues at all. the only thing that comes to mind is your speedometer will be off a bit. be best to check it and see if anyone you know can recalibrate it to the new tire size using a programmer.
you can go here http://www.1010tires.com/TireSizeCalculator.aspto compares sizes. diamaters. etc
Old Dec 25, 2006 | 12:49 AM
Mean Green's Avatar
Mean Green
I wouldn't imagine width would affect the speedo just height. I'd say as long as you stick with 32's then you'd be good to go and I've heard of some D's that were stock with 265's.
Old Dec 25, 2006 | 06:29 AM
bjo304's Avatar
bjo304
Mine are275/60/17, with no issues.It is 10.82 inches in width.Hopefully that helps.
Old Dec 25, 2006 | 10:44 AM
RebelX's Avatar
RebelX
ORIGINAL: Mean Green
lmao. your right. i read it wrong. was trying to reply and get ready for work at the same time....guess i cant multitask that well
Old Dec 25, 2006 | 11:40 AM
Dman98's Avatar
Dman98
I have 275/70/16 and have slight rubbing at full lock when making a u-turn. The tires only rub the front frame, so when I make a u-turn I don't go full lock.
