front end
Hello everyone I'm New to this forum Happy New Year.When i drive slow or when frist driving awy from a stop the steering wheel moves from side to side then gos away when I go faster. I rotated the tires a few weeks ago. the tires on the passenger side had more wear than the drivers side.Do you thin its the tires or something in the front end.any help i will be great fill for. thanks
I'm thinking ball joints. Get your ride a 4-wheel alignment. If you are having a problem then they will find it and they usually won't charge you. Then go fix the problem yourself. Then you can take it back after you work out the problem and get it aligned.
