1998 Durango Won't shift
Old Jan 15, 2007 | 11:56 PM
gumijagr's Avatar
gumijagr
Default 1998 Durango Won't shift
I have a 1998 Dodge Durango 4x4 automatic, (its actually my wifes) It has a hard time shifting out of 1st gear int 2nd unless you let up on gas a little then it shifts but if you get into the gas alittle it downshifts again to low, has new fluid and filter about a month ago and fluid is full, should I try changing the TRS transmission Range Sensor? Is it like the 2001? where can I download the manual for a1998 Durango? I found one for the 2001 on here and downloaded it just to try and get some ideas. Any help would be greatly aappreciated! Thanks for your time! New update now today it won't start unless we put it in nuetral won't start in park. Does it have a cable that I should replace?
