03 Durango Engine code?
Old Jan 21, 2007 | 01:45 PM
MBS313's Avatar
MBS313
Default 03 Durango Engine code?
My 2003 Durango is showing a PO440 engine code. Can anyone tell me what it means and if I'm going to have to take it to the dealer. The vehicle is running fine. I don't want the dealer to rip me a new one. Help!
Old Jan 22, 2007 | 05:42 AM
Mean Green's Avatar
Mean Green
Default RE: 03 Durango Engine code?
First thing to do is go buy a new gas cap. There is an index of engine codes at the top of this section heres a link. https://dodgeforum.com/m_614377/tm.htm
If the gas cap doesn't work tighten up all of your connections on the fuel lines.
Old Jan 22, 2007 | 07:52 PM
steve05ram360's Avatar
steve05ram360
welcome to DF...
Mean... is the 440 code for the small evaporative leak? I thought it was 442...[&:]
Old Jan 23, 2007 | 01:29 AM
MBS313's Avatar
MBS313
Should I get a replacement gas cap from somewhere like Advance Auto Parts or do I need to get one from a dealership?
Thaqnks for your help.
Old Jan 23, 2007 | 01:31 AM
MBS313's Avatar
MBS313
Ater replacing the gas cap will I need to diconnect the battery to reset the computer and turn off the check engine light??
Thanks
Old Jan 23, 2007 | 01:36 AM
Mean Green's Avatar
Mean Green
You're right Steve it wouldn't be the gas cap unless there is a huge crack in it or something [&:].Sorry for that advice. I would look at the fuel lines and I think the most common area to get the leak is in the filler neck going into the tank. Make sure it is all seal up well.
Old Jan 23, 2007 | 05:20 PM
MBS313's Avatar
MBS313
After checking the the gas filler hose, how do I reset the computer??
Thanks
Old Jan 23, 2007 | 06:24 PM
Chris's Avatar
Chris
You can disconnect the battery for 15 minutes which will reset the whole system, or you can pull the fuse to your ecm which will keep your clock/radio settings and reset your check engine code only.
Old Mar 4, 2007 | 05:18 PM
lobster1's Avatar
lobster1
where is the fuse for the ecm.
Old Mar 4, 2007 | 05:55 PM
duelsxt's Avatar
duelsxt
ORIGINAL: Mean Green
Thatis incorrect. I took my D to the dealer under warranty 5 times. They always said it was a fuel or vacume line we found it its fixed. Two days later the check engine light was back on. I told them to replace the gas cap because I had the same problem with my old dakota and it was the cap. Finally ater getting tired of them I replaced it myself and reset the light. It never came back on. Save yourself the hassle buy a $12.00 cap...
