Power Window Problems/ 4WD Light
Old Jan 26, 2007 | 08:13 PM
emarkowi's Avatar
emarkowi
Default Power Window Problems/ 4WD Light
I got a 1999 Dodge Durango. I am the original owner. Two problems that anyone has any insight on would be appreciated.
1. my passanger side window won't go down. I tried switching the fuse and that didn't work. It's just that window that doesn't work. THe rest work fine.
2. the light on the dash doesn't come up with I switch into 4WD low or high..
emarkowi@yahoo.com
Old Jan 26, 2007 | 09:22 PM
ganzhimself's Avatar
ganzhimself
Default RE: Power Window Problems/ 4WD Light
1. The actuator motor could be bad.
2. Perhaps the bulb is burnt out. Or maybethere's a bad switch or relay somewhere between the selector and the light.
Old Jan 29, 2007 | 06:46 AM
Mean Green's Avatar
Mean Green
https://dodgeforum.com/m_650637/tm.htmHeres info on the window
