Will these fit?
Old Feb 2, 2007 | 09:38 PM
pedal2themedal's Avatar
pedal2themedal
Default Will these fit?
I have found alot of tidbits, but nothing exactly like i want, i have a 00 durango, 5.9 4wd, and it has rt 17" wheels, i have found a good used set of 285/70/17's. Will those fit or can i make them fit without a lift kit? If not, what is the biggesttire i could fit under the stock wheel wells?
If I got a 3" body lift, what would be the biggest tire i could fit??
Thanks for your help, Robert
Old Feb 3, 2007 | 10:28 AM
pedal2themedal
Default RE: Will these fit?
anybody know???
Old Feb 3, 2007 | 12:00 PM
deerang's Avatar
deerang
what is the total hieght of those tires?? they most likely will not rub being 10.5 inches wide, but I don't know what 70R17 is. I think they are 33's which means they will rub at stock height, and probably even with the 2 inch torsion shackle lift.
The biggest you can fit under stock without any rubbing are 31's, with 2 inch lift you can fit 32's (other thread somebody says they rub in reverse), and with 3 inch body lift and 2 inch you can fit 33's, possibly 35's (don't quote me)
Old Feb 3, 2007 | 01:42 PM
deerang's Avatar
deerang
Width = 285Sidewall = 70Wheel =17
Diameter = 32.7Section Width = 11.2Section Height = 7.8
most likely will not fit under stock wheel wells....2 inch lift will most likely rub on full-lock turns
