? about matince.
Old Feb 3, 2007 | 08:50 AM
340magnum's Avatar
340magnum
Default ? about matince.
I have a 98 Durango I was wondering what kind of matince I should do since it is about to hit 86000 miles on the od. I bought it when it had 84000 I just want to keep up so the warranty I have stays vallid.
Old Feb 4, 2007 | 09:33 AM
Mean Green's Avatar
Mean Green
Default RE: ? about matince.
I would change the plugs, wires, cap, rotor, all fluids (oil, tranny, transfer case, diff/diff's), T-stat, and check the belt. Also see if you can get a hold ofany maintenance records on it and you may save a few $$$. When you do the ignition components stick with Champion plugs and don't get cheapo stuff, stick with OEM or go with MSD ignition components.
