2002 Durango somtimes hard to shift out if park
Old Feb 12, 2007 | 10:57 PM
jej826's Avatar
jej826
Default 2002 Durango somtimes hard to shift out if park
It doesn't matter if I am parked on a level surface,or a hill with the parking brake on.Every once in a while it has a hard time shifting out of park.Eventually it does shift into gear if I keep playing with the shift lever.Any ideas?
Old Feb 12, 2007 | 11:01 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: 2002 Durango somtimes hard to shift out if park
it might just be out of adjustment.
how much snow do you have there? I was hitting snow banks and drifts on the weekend and then I couldnt move the gearshifter. I found that there was soo much snow compacted in there that it wouldnt let it move. but I doubt thats your problem.
I would just go down there and lube everything up.
Old Feb 13, 2007 | 10:44 AM
deerang's Avatar
deerang
https://dodgeforum.com/m_681621/tm.htm
Old Feb 13, 2007 | 10:36 PM
jej826's Avatar
jej826
Thanks.
Old Feb 13, 2007 | 10:38 PM
jej826's Avatar
jej826
ORIGINAL: jonnymagnum
No snow at all.I'll try lubing everthing up.
Thanks
Old Feb 15, 2007 | 09:42 PM
jej826's Avatar
jej826
deerang,thanks for the link.Pulled the rubber boot off shift lever,and saw the steel rod was not pulling back when key was turned on.Sprayed it with WD-40.Works as good as new again.The job took less than 5 mins.THANKS AGAIN!!
Old Feb 16, 2007 | 12:33 AM
deerang's Avatar
deerang
No problem jej826. Good to hear you're back up and running again.
