Trim Piece Needed
Old Feb 19, 2007 | 12:32 AM
uniquestylz's Avatar
uniquestylz
Default Trim Piece Needed
I need to know if anyone either has a part number or an actual part for the black trim piece located by the 4x4 shifter on the floor of a 98 durango. The piece or part number for the piece that i need, is the plastic or rubber bin, on the floor, which inserts into the floor trim piece. It is to the right of the 4x4 shifter. Thanks...
Old Feb 19, 2007 | 12:34 AM
Sapper89's Avatar
Sapper89
Default RE: Trim Piece Needed
The rubber mat that you can remove and wash?
Old Feb 19, 2007 | 12:41 AM
Sapper89's Avatar
Sapper89
Numbers off the back 258622 or 55055912AB
Hope this helps, mines a '99
Old Feb 19, 2007 | 01:01 AM
uniquestylz
thanks a lot. I will run that number by the dealer. but yeah it should be the one that you wash. About 6 inches by 7 inches.
Old Feb 19, 2007 | 01:13 AM
Sapper89's Avatar
Sapper89
post back I'll check tomorrow, if not seems like the reg's will be all over it.
