Window Regulator '03 Durango
Old Feb 20, 2007 | 11:44 AM
durango037's Avatar
durango037
Default Window Regulator '03 Durango
Hey guys. Anyone who saw my previous thread knows I had a problem with a rear drivers side window regulagtor. Anyways, the thing broke during the deep freeze we had here in Toledo, OH and I went the easy way out and bought a regulator from a '02 Durango (I think). So, I pull the door apart and find out that everything is the same, except the regulator and its mounting locations. Then, I find out that it doesn't work, so I thought. Turns out that in order for the window to operate in the rear you must complete the circuit through the rear door window switch. I did not know this and had the rear window door switch unplugged. Took a multimeter to it and found out the problem and that solved everything except mounting the regulator. I struggled with that for a while and finally made it work. So, FYI '03 Durango regulators are different than the previous years and if you want to make it work at a cheap cost this is the way to go. Hopefully this helps anyone in the future.
TTYL, Love my Durango. Will have pics soon as well as updates on future mods.
