Need code help
Couple of codes i need help decoding P1776and code P0734 any help would be appreciated.
Oh by the way it's a 2000 durango 4.7 engine. Also car hesitates and sometimes when pulling out has no power.
P0734 Gear 4 Incorrect ratio
I could not find P1776 for some reason but I know it is an OD malfunction which would make sense with the P0734 code. You may be looking ata rebuild. If you do a search on "tranny" you should be able to find my post on this because I had the same 1776 code right before my OD section blew up.
