1st Gen Intrepid 1993 through 1997 Intrepids
detonation
Old May 21, 2007 | 07:00 PM
spiral72's Avatar
spiral72
Default detonation
I havea 95 Intrepid 3.3L with 215,000 miles. The car is still in excellent condition due to religious maintenance on it, but it's getting old.
I've had the same problem on a couple high mileage vehicles and am trying to work this out..... and would like some ideas.
The engine has started detonationg under a heavy load (up hill) in O.D. and even in 3rd gear on a very steep hill. I run and have always run 87 octane BP/Ameco gas. The temp is about 1/3rd (if accurate), the ignition system is about 10,000 miles old and it started this before the new parts.
The plugs look good with a normal color and I still get about 32mpg.Higher octane gas doesn't seem to help much, neither does the temperature outside summer/winter. Any ideas?
I figure (maybe) that due to carbon buildup on the top of the piston, it increases the compression ratio over time. No?
I could:
run higher octane gas (which I am going to try 93 octane on my next fill-up)
try a colder spark plug
run a cooler thermostat
redard the timing, isn't it computer controlled?
Live with it until my engine grenades.
Old May 22, 2007 | 02:29 PM
spiral72's Avatar
spiral72
Default RE: detonation
Well, this forum appears to be dead.
Any links that can tell me how to set the timing? My google searches turned up null.
Old May 29, 2007 | 11:28 AM
spiral72's Avatar
spiral72
For the record, it was a faulty O2 sensor.
Old May 31, 2007 | 02:55 AM
kurts2's Avatar
kurts2
yea, I know the feeling! It is rather dead. I have been away for a bit, and I'm not seeing too many others giving input. I am about to quit myself, I only hang in because I think maybey I can help someone. If you find a more livley fourm, let me know.
