Intrepid 96 Check Engine Light Codes 45 46
Hi everyone, does anyone knows about codes 45 and 46 on an Intrepid 96 3.3L?[:@] 46 is from voltage too high I think, but what is the 45? All I can find is something related to the turbo which this car does not have. ( do any intrepid have one anyways?) The car seems to run fine, the crank sensor hadbeen replaced last week and the engine grounds had been redone a few days ago. We think that the battery is dying slowly[&o] but do you think that the code46 could be related to this? any inputwould be appreciated.
Thanks!
EDIT: btw I triple checked the codes and it is 12 - 45 - 46 - 55
12 - battery disconnect
46 - voltage too high
55 - end of codes
45 - ?????
Thanks!
55 - end of codes
45 - ?????
A MIL 45 (obtained via the check engine light flashing) is an indicator that you have a trany fault in the TCM. Bring it to a trany shop to determin what is wrong.
