1st Gen Intrepid 1993 through 1997 Intrepids
3.5 litre crank pulley
Old Sep 4, 2019 | 02:40 PM
Kayla Jones's Avatar
Kayla Jones
Originally Posted by master tech
I replace timing belts without removing the crank pulley.
How would I remove my timing belt without removing the crankshaft pulley?? I am actually trying to remove my cylinder head to change my head gasket, and when I go to turn the bolt to remove the cam sprocket the sprocket turns as well! So my thinking is if I remove the timing belt, it will allow me to turn the bolt without the sprocket turning on me
