DWD2 evap cleaner - need help
Have a 93 intrepid 3.3L. Got some DWD2 to clean out the evaporator, and attach a hose to easily clean out in the future. Just got the bottom part of the dash out and am having a hard time figuring out what to do next. All the instructions I can find are for taking the evaporator out. I just want access to be able to spray this cleaner stuff in
Oh - Also can not find the Evaporator Drain Hose, to make sure it isn't clogged.
Any help is appreciated!
ok - figured it out. The drain routes through the firewall and under the car. it goes along the bottom and doesn't hang down very far. if you get to the heater housing just follow the part that goes through the flloor. the drain is inside of it.
also, put the evaporator cleaner "injector screw" into the cylinder shaped part between the blower motor housing and evaporator/heater core housing. there was plenty of room and no chance of damaging any heater parts. aimed the screw at the evaporator. have pictures of this and can post if anyones intersted. the car smells a lot better with the AC on, though not completey smell-free. am hoping the cleaner will get rid of all the mold within a few days. if not I have another refresher can of DWD2. since the hose is in now in place, I can spray chemicals in there to my hearts content.
