Fan blower not working
Hello,</P>
My girlfriend's intrepid's blower fan seems to have just quit working this morning. Of course it has to pick a nice COLD day to do this. She says she can feel a little bit of heat when her hand isin contact withone of the vents, but the blower is not blowing any air through...no matterwhat speedshe has the fan turned up. Any ideas?</P>
I think this may be related to a problem she's been having for a better part of a year or so.Intermittently whenshe had the fan on for heat or AC, there was a noise coming from the dash..like a low-high pitched hum or whine.</P>
</P>
Thanks in advance!</P>
Thanks!</P>
That's what I was thinking. A couple of other people had told me to check the fuse first. While that may be true, I think the fan was definitely on the way out, so thatis going to need replacement anyway.</P>
Any ideas on how easy this is to do that '95 Intrepid? Also, I've never replaced one of these before...does the fan and motor usuallycome as an assembly together?</P>
</P>
You might also want to check to see if there is a blower motor resistor on the car. I recently just had the same problem on my Dynasty, and it ended up the blower motor went out with the blower motor resistor. Replaced both, and the heat worked again.</P>
</P>
Just some food for thought.</P>
I bought a new heater core to put in my Shelby Z, then I found out where it was and went with Aluma Seal. <img border="0" src=smileys/smiley36.gif border="0"> I still haven't changed it. Most newer cars are evil with the location these things, up under the dash behind everything. My Roadrunners heater is in almost plain sight under the dash on the passenger side, great easy access.
It's probably an assembly, but could be seperate. Either way you only need the motor, and as 90dynasty said you may also need the resistor.
