1st Gen Intrepid 1993 through 1997 Intrepids
Short circuit
Old Dec 10, 2004 | 08:15 PM
Lou's Avatar
Lou
Default Short circuit
THis INtrepid 1994 has developped a short circuit somewhere in the tail/parking light circuit, but I can't locate the place exactly. ANyone experienced this ? Instrument panel lighting is also served by this circuit.
Old Jan 2, 2005 | 10:23 PM
Lou's Avatar
Lou
Default RE: Short circuit
Well we found it: the 15 amp fuse to the parking light circuit kept blowing. The parking light circuit itself proved to be OK because once the Body Control Module was disconnected, the lights would light up normally. But when BCM was connected, then an input from the light circuit to the BCM tells it to feed the dash lights and then, the fuse would blow.
Well...I am "short circuiting" a long part of the story here because first, to access BCM, you have to remove the lower dash panel....and thanks to partial diagrams I was provided with, I knew pin 23 was the parking light input to BCM..so I could disconnect it for the test.
After jiggling with wire harnesses and causing the short to come and go and seeing some sparks from under the dash, it proved necessary to remove it all....and this is no piece of cake......
Anyway, the results are here, and shows some wiring was not routed properly when the car was built:
www.geocities.com/lmp4203/intrepid/DSCN2465s.JPG
www.geocities.com/lmp4203/intrepid/DSCN2466s.JPG
www.geocities.com/lmp4203/intrepid/DSCN2467s.JPG
www.geocities.com/lmp4203/intrepid/DSCN2469s.JPG
