1st Gen Intrepid 1993 through 1997 Intrepids
93 intrepid ES front end problem help
Old Jan 15, 2005 | 02:16 AM
hoppy's Avatar
hoppy
Default 93 intrepid ES front end problem help
When driving at times I experience a up and down movement in the steering wheel and it's a violent movement. Doesn't happen all the time going up hills or letting off the gas. Outer tie rod ball joints replaced. Bushings on the inner tie rod to steering box and steering box bushings are replaced. Thoughts?
Old Jan 16, 2005 | 12:52 AM
Lou's Avatar
Lou
Default RE: 93 intrepid ES front end problem help
...I'd check for engine / transaxle mounts..at least to be sure this option can be put aside..
