1st Gen Intrepid 1993 through 1997 Intrepids
1995 brake problem
Old May 27, 2008 | 01:08 PM
mrt1963's Avatar
mrt1963
Default 1995 brake problem
i hope someone can help me. ichanged the front driverside wheel bearing. when i put it back together i got a soft brake pedal. i pushed the caliper in a small amount just to put it back on. i bled out all the lines and still have a mushy pedal. when the car is off i get a hard pedal. the car still stops but you can push the pedal down to far. please help me. this is making me crazy..thank you for the help.....
todd
Old May 29, 2008 | 08:53 AM
kurts2's Avatar
kurts2
Default RE: 1995 brake problem
I'd say you still have air, re-bleed.
Old Jun 11, 2008 | 07:14 PM
dodgewilltravel's Avatar
dodgewilltravel
I changed the front brakes on my wifes 96 intrepid and the same thing happend. I bleed the brakes it seems 100 times and still happends, a friend of mine told me to change the rear brakes and that it should be ok, i did that today and the brakes to me seem fine, but the true test will come when the wife drives it. will follow up later.
Old Jun 12, 2008 | 09:20 PM
dodgewilltravel
as I was saying my wife drove the car today and she said that her brakes were better and harder, so conclusion on brakes is any messing with the calipers tells the abs that theres a mishap, all hell breaks lose. What more can I tell you? My wife is happy with the outcome.
