95 Intrepid with OBD-1
This is the knock sensor not working or intermittently working. The most common problem found with this is a bad connection between the actual knock sensor and the pigtail connection to it. These are located in the coolant drain at the lower part of the block.
____________________________
Check out Autopartswarehouse
Drive Safely and Move Freely
