Hey all, my 95 just started running the engine fan all the time. Everything looks ok fluids wise so I'm down to the coolant sensor or a servo/relay. Has anyone else had this problem?
could be a poke in the dark but will only take a seacond to try, try switching the fan relay with the horn relay, if fixes the problem there like 10 bucks at advanced auto or damneer free at the salvage yard, can't say thats it, but always try the simple stuff first.
As per A/C high pressure switch. Just unplug the switch which is locate bottom passanger side of Rad. If the pressure switch is bad it will run on high fan continuosly. Just another possiblility to narrow down problem.
