1st Gen Intrepid 1993 through 1997 Intrepids
97 Intrepid engine control fuse
Old Dec 12, 2008 | 07:02 PM
mektek's Avatar
mektek
Default 97 Intrepid engine control fuse
I have a 97 intrepid with a 3.3l. It blew the engine control fuse located in the power distribution center fuse box. replaced the crank sensor and coil pack and added a 30A fuse to get it to run. 3 weeks later , it blows again while idling in the driveway. shake some wire harnesses, disconnect and reconnect sensors, replace 30A fuse and it starts again. Anybody got any ideas what may be causing the fuse to fail intermittently?? thanks
