Oil sensor on 95 intrepid 3.5
I've heard many conflicting stories on where the oil sensor is located that I haven't the foggiest idea of where to find it.
Can anyone help? Also, is it hard to change?
Thanx...
Thanx...
I assume you mean the oil sending unit. If so it is located on the drivers side of the engine next to the Oil filter. It is relatively easy to remove (much like the O2 sensors)
If you don't want to buy a socket to remove it, just wait (if you can) until you change your oil. When you have the oil filter off you will have more room to just use an open end wrench. Remember to use some teflon tape when you reinstall so you wont have a leak.
