1st Gen Intrepid 1993 through 1997 Intrepids
Help on a 1995 dodge intrepid
Old Mar 25, 2009 | 06:53 AM
future_paramedicheather's Avatar
Unhappy Help on a 1995 dodge intrepid
Hello all! A quick question for the mechanics in the bunch. I had a belt break on my vehicle. According to the belt diagram sticker on my car its the belt that runs the A/C unit. The serpentine belt or drive belt or whatever you want to call it (the wide belt with ridges) is still attached and working very well. I would like to know if it is safe to drive my vehicle without this belt. Again, I have a 1995 Dodge Intrepid with a 3.5L motor.
Thanks!
Old Mar 25, 2009 | 11:10 AM
iowa_68coronet's Avatar
iowa_68coronet
I have seen 3.5 cars run without that belt before. If I remember right the only thing that belt drives is the AC.
Old Mar 25, 2009 | 05:08 PM
kurts2's Avatar
kurts2
Yes...for the most part. The belt is only for the AC but your defog won't work at all until the engine gets hot. Normally, when you select defog, the dry air from the AC clears the winshild in seconds. If you are an old timer (like me) you will remember sitting in the driveway for 5-10 min waiting for the engine to get hot enough to dry the windshield.
Old Mar 26, 2009 | 05:15 PM
Thank you for all of your help! Just wanted a confirmation from those that deal with engines more than I do! lol I was always raised to know how to change oil and brakes, and couldn't leave the yard unless my gas tank was half full and my tires had good tread, but engines I was never big on.
Thanks again!
