1st Gen Intrepid 1993 through 1997 Intrepids
94 Intrepid Rotor Specs
Old Apr 12, 2009 | 12:58 AM
Casse's Avatar
Casse
Question 94 Intrepid Rotor Specs
Hi. Need the minimum thickness specs for front rotors on a 94 [1st generation] Intrepid 3.3L Automatic w/ 68K on it. My repair manual says the spec is stamped on the rotor, but that area is so rusted I can't make out the number. The rotors seem to be OK; no gouges or high spots, but I need the specs before I either get them turned or buy a new pair. Thanks.
Old Apr 13, 2009 | 03:42 PM
kurts2's Avatar
kurts2
97 book (should be the same) front rotor info...
thickness 24.13-23.87 mm (.950-.940 in); minimum thickness 22.4mm (.882 in); thickness variation .013 mm (.0005 in); run out (if you have their special tool) .08 mm (.003 in); Rotor micro finish (??) 15-80 RMS
Kurt
PS here is the rear while I'm here (all the same except thickness & min thickness. They are...
Thickness 12.13-11.63mm (.478-.458 in); min 10.4 mm (.409 in)
Old Apr 13, 2009 | 03:48 PM
9neon5's Avatar
9neon5
ondemand5.com
Old Apr 14, 2009 | 10:34 PM
Casse's Avatar
Casse
Default 94 Intrepid Rotor Specs
Thankx a lot. I appreciate the help and your time.
Old Apr 15, 2009 | 01:04 AM
kurts2's Avatar
kurts2
Your welcome. I hope you were able to turn them.
Kurt
