1995 Eagle Vision 3.5 TSI
I have a question for all u mechanically inclined individuals... I've just recently gone through heck with my Car. But the problem i'm having should have been easy to fix...so I thought. I have this pulsing/surging when I'm going a constant speed. I replaced the tranny cause it died a couple months back. It did it before I made the switch and after. I just replaced the fuel filter...buuuuut, on the fuel rail while releasing the fuel pressure, I think I may have got the pin stuck inside while using a flat head screw driver to release it. But, may not be anything. To scared to take the cap back off! Anyways, Before I changed my fuel filter today, it was stalling. Immediately AFTER i let off the gas. After I changed the fuel filter, I don't stall...but it gets close. And the car still surges at a constant speed. I checked everything out and their isn't any gas leaks. When i'm going like a constant 25 and I let off the gas, it seems like the rpms dip way down past 1k and then comes back up. It has to be fuel related. Thought it was the filter. now that I have gotten that outta the way, the only other things I can think of is that one of my oxy sensors is bad or the fuel pump is starting to die. I need some advice. I'm new to forums so feel free to offer any assistance.
I own a 1995 Eagle Vision 3.5 TSI. If you need any more info to help you help me...let me know!
Thanks in advance.
Thanks in advance.
I forgot that I even had this posting up till I just looked for the exact same problem, just now I have replaced the fuel pump because that died. I actually think I may have a coil pack that has gone bad...Which is pretty much where ur advice is taking me. I will also prolly replace the plug wires and plugs just to be on the safe side. I will report back in the next week or so to let you know my progress. Thanks guys for the assistance!
its been a while but is there an update to this string. My 95 vision is doing the same spuddering only when trying to accelerate. and seems to stop giving me problems after the engine light pops on. any ideas?? thanks in advance
