1st Gen Intrepid 1993 through 1997 Intrepids
ignition key stuck intermittently
Old Feb 26, 2010 | 05:40 PM
nickstermon's Avatar
nickstermon
Default ignition key stuck intermittently
94 Dodge Intrepid's ignition key gets stuck intermittently. Can turn engine on & off OK, but sometimes I just can't get the key out. When I can't, the oil light stays on & it runs the battery down overnight. Anyone have a solution?
Old Feb 26, 2010 | 07:56 PM
Dodge4lyfe's Avatar
Dodge4lyfe
Have you tried a freshly cut key? When my key edges get worn and rounded it doesn't want to turn the ignition cylinder correctly. Only other thing is that the ignition cylinder itself is bad.
Old Feb 27, 2010 | 09:56 AM
nickstermon
Have not tried a freshly cut key, but have the same problem with my wife's key. She rarely used the key so I don't think the key is the issue. Anything else?
Old Feb 27, 2010 | 11:20 AM
Dodge4lyfe's Avatar
Dodge4lyfe
Hmm, i guess the next thing to try is to get a different ignition switch and put your lock cylinder in it. It sounds like the rotating mechanism in the switch may be bad.(It's a fairly common issue.)
Old Feb 27, 2010 | 12:35 PM
nickstermon
Default ignition switch
What a ballpark cost for a different ignition switch?
Old Feb 28, 2010 | 07:55 AM
Dodge4lyfe's Avatar
Dodge4lyfe
Rock auto's got one for 15 bucks
