1st Gen Intrepid 1993 through 1997 Intrepids
hazard troubles
Old Mar 3, 2010 | 06:47 PM
brcdodge's Avatar
brcdodge
Default hazard troubles
having issues with the hazard lights on my 94 intrepid 3.3L . the turn signals work just fine, but the hazards will not flash. . . i bought a new flasher relay and replaced it but nothing changed. . . i have looked in the engine compartment fuse box and in the drivers side panel fuse box and could only find a turn signal fuse, not a hazard light fuse.. . .. . neither the hazards or turn signals work when i turn the hazard light switch on. . . the turn signals will only flash when the hazard button is pushed in and turned off. . . any help on how to fix this or why this may be happening would be much appreciated . . thanks
