1st Gen Intrepid 1993 through 1997 Intrepids
2001 intrepid rear main seal problem
Old Jun 16, 2010 | 10:50 PM
stevenson558's Avatar
stevenson558
Default 2001 intrepid rear main seal problem
I have replaced my main seal like twice with seals from pepboys, and auto zone and it still leaks. So i went to the dealer and got the dealer seal that came with the cover with it and it stills leaks.. What am i not doing or doing wrong??
Stevenson
Old Jun 27, 2010 | 04:51 AM
jarrod27's Avatar
jarrod27
does your crank have a groove in it were the old bad seal rubed a groove in it? Because if it did you must replace your whole crank because it will never seal. And did you do a good uv oil light treatment and make sure that is were your leak is coming from.? Dont just asoome that its the rear main seal.
