No Start Diagnosis Help Needed
'95 Intrepid 3.3L (No-Flex)
I did the steps in the No-Start Procedures part of the Shop Manual.
Found bad Cam sensor and replaced it.
Then, with test light test, I get possible bad circuit for cam/crank sensor result (Light flashes with key on, light will not flash while cranking).
I have replaced the fuel pump and am getting 55psi at the rail.
I checked the coil resistance secondary (across towers) within specs. Primary (at the plug from ASR) pins slightly out of spec (0.45-0.65) mine read 1.3 ohms one one meter and 0.8 on another meter. Temp today was in the 70's.
Not getting fire at plug 2 but stopped testing plugs because ASR shuts down coil.
Next step is check the volts at the Cam and crank sensor plugs again ( last time I checked it was within spec).
How do I test 5 volt ground circuit?
How do I test the crank sensor?
Considering bypassing the ASR to see if spark plugs get fire.
Any suggestions?
Thanks a bunch!
Any suggestions?
Thanks a bunch!
